TECHIES: LEDs in turns, which wires to tap resistor into?
<center><img src="http://img.photobucket.com/albums/v349/20VTURBO/DSCF1168.jpg"></center><p>My new LED turns are rapid firing and I don't know which wire to tap to put the resistor in!
The front is a bit different than the rear as you have the "parking" lights and then the blinker. I'm not sure which is which though. I'm sure they share the ground wire.
You might wanna try trial and error, you have to cut 2 wires at minimum anyways. Do you know how you have to wire in the resistors? It took me a while so if you have any questions, just ask.
