technical Question:Why is the front sway bar(neuspeed 29mm) larger than
the rear sway bar(neuspeed 19mm) and why would replacing the rear make more of radical improvement if the front is of a larger size?
Automobile manufacturers intentionally design a cars suspension towards understeer.
Generally considered to be easier to "control" than the opposite (rear end breaking loose first and putting you into a spin).
a better "feel" of what the car can do and what it's going to do.
Unless heavy suspension modifications are made to your car, the beefier rear bar shouldn't make your car dangerous or hard to drive at all. That is, of course, if you are an average driver.
a 28mm bar on an audi in the rear is way high... and would be too much... but 29 on the front isn't too much... they aren't comparably really...
hey, you can get a 29mm REAR in a volvo...
jersey 4 rings
12-18-2006 07:15 AM
nverfollow
03-25-2004 11:43 AM
MikekiM@PureMS
04-02-2002 02:08 PM
White Coupe
03-27-2002 10:13 PM
