Is there any real way to check for engine sludge?
You need to drop the subframe to drop the oil pan which also means getting a alignment because of moving the subframe. I wouldn't sugest it.
Drain a quart of oil out, add a quart of aggressive engine flush, let the engine idle for 15-20 mins, drain everything out and change oil/filter. If you use synthetic oil, it's almost certain that you have zero sludge.
Cheers,
Cheers,
floorit
13
09-29-2006 11:32 AM
1st time Audi lover
10-04-2004 07:23 PM
