Is there any way to convert the B5 tranny in the 1.8t to ....
the 04 6 speed tranny out of the B6 1.8t? My sister just got the B6 with the ultra premium sport package and I loved the 6th gear....its in my opinion what all B5s need to cruise at 80 mph withough running the rr's up in 5th.
Re: it will probibly be easier than an S4 swap!
i would hope so...the block is the same as the ole 1.8t's....just not sure if the links to the four wheels is the same lenght and what not....thanks
Actually......
It's most likely that the 6 speed in the '04 1.8T is identical to the B5 S4's. Differences from the 5 speed to the 6 speed are: center driveshaft, axle flanges, linkage, final drive, and mounts. With the B6 setup, you would only need the "DTS" style mount, rather than the two side trans mounts. Much simpler, IMO, but still very spendy. My '97 A4 2.0TQMS has an S4 6 speed driveline.
Re: Doubtful. The B6 6-sp shifts much better than any B5 S4 tranny, and...
Letter code FRE = 01E 6 speed, with a final drive of 4.375. Used in 3.0L B6's.
letter code GJW and GJV = 02X 6 speed, final drive of 4.11(GJW) and 3.889(GJV- e-code?), used with both 1.8T and 3.0L B6's.
letter code FVD = 0A3 6 speed, final drive 3.889. Used in B6 S4.
letter code EDU = 01E 6 speed, final drive 4.11, used in B5 S4's.
I stand corrected. ;-)
you can drop in the 2.8 5sp and the revs will drop 250-300 on the freeway...
and much cheaper than doing a 6sp conversion.
I'm having a 2.8 tranny (code DWM) swapped out as we "speak."
and adding the new AMS SS.
will now be a much better freeway cruiser.
