Is there a bulb behind the odometer/tripmeter?.... more
Guest
Posts: n/a
The gauge that registers the mileage and distance since last reset seems to have died. Is this a LED matrix which has broken or just a bulb behind the digits?
It would be handy to know this before Friday as the car is booked in for some other warranty work and if it's not just a simple bulb replacement I'll get them to fix it.
Peter
Guest
Posts: n/a
don't want those pesky dealers taking apart my dash again. I still had to put it back together properly after their last excursion.
1996 a4 2.8 qm 12v
wheres my supercharger!!
1996 a4 2.8 qm 12v
Guest
Posts: n/a
If it is under warranty, have them fix it.
I recently had to replace two lights on the instrument panel - one on the top of the tach and one on top of the speedo. I do not recall if there is a light on the section you are talking about. The panel is really easy to take off. You just remove the plastic piece over the steering wheel which is held in by two clips and then there remove the two screws. The whole instrument panel can then be pulled out.
Guest
Posts: n/a
Aren't bulbs are excluded from the warranty?. The labour to remove the dash would therefore be chargeable, I don't want to pay 0.5hr labour to fit a 50c bulb.
I'll have a look at it tonight.
Peter
Guest
Posts: n/a
My 1998 USA Warranty book specifies that brake pads, clutch disk friction material, bulbs other than headlights, blown fuses, wheel alignment, and tire balancing ARE NOT covered by the Audi Warranty. However, they ARE ALL covered by Audi Advantage.
Kevin Craig
98.5 2.8 QTip Avant
Kevin Craig
98.5 2.8 QTip Avant
Guest
Posts: n/a
The mileage/trip display definitely looks like an LED; if display is dead, either power is gone or display controller is shot would be my guess. I would expect that if total display dies, it's some sort of power supply. I normally have seen LEDs die in one small section at a time (like the trip computer display).
The climate control display looks similar; LED vs. an LCD that needs separate bulb to light display. Once again, if total display goen, would expect it to be a power supply lead or the controller for the LED.
Guest
Posts: n/a
I don't know exactly how the display works, but I have noticed that if the sun hits it just right, you can read the mileage even when the car is off. This suggests to me that it is an LCD display with a light source. But that is just a guess on my part.
Kyle
Kyle
CactusGreen
09-23-2006 06:47 PM
Tinfly
12-21-2004 04:57 PM
CK NYoC
04-20-2001 11:52 AM
