For those of you who had the random cyl. misfire/No.2 cyl. misfire problem...
what did you do that ended up fixing the problem? I've combed the archives and found that this is a pretty common problem, especially for those who just got chipped. Some of the things I found to check:
- swap coilpacks, sparkplugs
- check MAF
- check ignition control module
- check all wirings/harnesses
- replace BPV
- check spark plug gap
So what'd you all do that fixed this? Thanks and Happy Easter!
- check MAF
- replace BPV
Had the same problem and turned out to be the coilpack connector...
The part that connects the coilpack to the sparkplug. check that first by swapping it with a different cylinder (just the connector) and see if you get a misfire on the cylinder you swapped it with (bad connector) or if the misfire stays on the same cylinder (coilpack, ICM, sparkplug, etc)
KEVOZS8
07-13-2007 08:08 AM
heateris
12
02-01-2006 01:29 PM
VA_Esfour
9
02-10-2005 04:31 AM
