Thoughts on running water vs. antifreeze for the summer?
the more anti-freeze you run the hotter the car will run...plain and simple.
If you want lower temps try Red Line Water Wetter...it does work. Lots of guys (racers) run pure water with water wetter. All water wetter does IIRC is reduce surface tension so that the water can come into more intimate contact with the cooling system components thus transfering more heat, I think it's basically a soap like material.
I can't find any specific references but I believe that antifreeze also will increase your boiling point vs water alone.
