Throttle lag between shifts with a 5 speed??
Guest
Posts: n/a
Just got my new 1.8T with quattro and a 5 speed. As delivered, the car has a realy annoying throttle lag between shifts - where the engine management system keeps the rev's up between shifts despite my lifting off the throttle. Does anyone know how to disconnect or eliminate this?
Feel like a damn novice with this throttle delay.
Guest
Posts: n/a
You'll get used to it...
...I noticed this also on my '97 1.8Tqms when I first got it. I've heard two theories as to why it does this:
1) The ECU keeps the revs up in between shifts to help cut down on exhaust emissions.
2) Audi uses a heavy flywheel.
I'm not sure which is the true story but I think you'll find that you get used to it over time...at least I did.
<A HREF="Mailto:andy_hedin@hotmail.com">Andy Hedin</A>
'97 A4 1.8Tqms, Garrett 1.0 Bar, ABT Filter, Borla Exhaust, European Headlights, more...
Guest
Posts: n/a
Re: Throttle lag between shifts with a 5 speed??
This is definitely a "feature" to reduce emissions. I'm not too sure on the particulars, but the car really puts out a lot of crap if the engine revs fall too fast...so the ECU keeps them up between shifts.
Focus on what your a$$ is telling you about your acceleration
Guest
Posts: n/a
I just work with it. When driving non aggressively I just wait until the revs come down to match
the rpm to the next gear. Makes for very smooth shifting. When driving faster I actually like the ""feature" as it holds the revs making more power in the next gear. You'll get used to it.
