throttle problem
Heres my two problems.
Vehicle: 99 Audi A4 1.8T
no engine mods (yet)
Problem 1
My timing belt broke which in turn bent my valves. I had a new head put on. I got the car back and it has no throttle response. Its very slow coming from a dead stop. When I lay on the gas at high speeds the rpms go up at first then drop for a second before they start going up gradually. The car is very slow now especially at slow speeds it seems like when I press on the pedal the rpms rev high but the car just doesn't actually take off as fast.
Any help would be appreciated.
Is there something I can do. new seals? Reseal any of the hoses.
Or is the problem somewhere else?
Problem 2
When I got the car back I found out that the service place broke a piece on the throttle body. its the part where the throttle cable wraps around that wheel and the end of the throttle cable is held on by a wire tie. Does anyone know where to by a throttle body and if so is there a better or upgraded throttle body I can purchase instead of the OEM? I don't know a lot about this so any help please.
I will provide more detail if anyone needs it to help me.
Thanks all!!<ul><li><a href="http://www.sounddomain.com/memberpage/459863">http://www.sounddomain.com/memberpage/459863</a</li></ul>
Problem 1
Problem 2
~DonQPremiumTequila~
12-01-2004 01:45 PM
Sourdough Josh
03-07-2002 11:06 AM
