tie rod end won't come off inner tie rod...
I changed the tie rod end out on the right side of the car just fine. The tie rod end unscrewed from the inner tie rod easily. Other side was a different story, and 4hrs of frustration later, the car's left front side was back together the way it started: with a worn tie rod end and clunks every time I drive over uneven ground. How can I get the tie rod end off the inner tie rod if it's stuck? Also, the inner tie rod is <$50 on PureMS, but I don't know if it's a DIY? Any write-ups for the inner tie rod replacement?
Thanks,
Einar
Thanks,
Einar
... and use PB Blaster generously... is Aerokroil better? Should I heat up any other parts? For longer? What are the optimum tools to use to grab the inner tierod and tierod end?
Thanks,
Einar
Thanks,
Einar
Tourette(AFC2.812v)
10-01-2006 02:06 PM
ahaiceman
09-08-2005 03:43 AM
Hokie - STI avant
06-10-2003 11:06 AM
