Tie Rod not coming off
1999 1.8T. doing complete front suspension. First tie rod will not come off. lock nut loose. added a little heat to inner tie rod. and torqued the outer. Just spun the rubber isolation in the outer. any suggestions?
tried the famous pinch bolts. they came right out. put PB blaster on yesterday and put back together.
Going to give a another day and PB. If no go. Then going to melt outer end off TR, so I can get a hold of the threaded portion of outer.
Again any help greatly appreciated.
Yes, as said do them both (INNER AND OUTER) once you spin the rubber the car is not safe to drive, and the inners are not expensive. I have not had good luck getting them out once seized.
egustaps
09-17-2008 07:25 PM
S4Dean
03-28-2008 08:10 AM
omidius
11
09-10-2002 01:29 PM
