TIGHT short shift kit..
..I had a short shift kit installed and I was curious about how "tight" the shift should be. There are 3 levels of tightness on the B&M.. do you want it on the "tightest" setting?? wouldn't this make it HARDER to shift??
AudiWorld Expert
I wouldn't call them "levels of tightness"...
They are 3 levels of shift throw reduction. Keep in mind, the shorter the throws, the more force is required to shift and more likely the more notchy the feeling.
so the B&M will ALWAYS feel this "tight" ..
.. with the SHORTEST setting?? Also.. when I shift from 3rd to 4th gear.. I get a little bit of a weird "delay" if you will.. which momentarily pauses the shift.. any ideas??
AudiWorld Expert
Re: so the B&M will ALWAYS feel this "tight" ..
Well, I don't know from personal experience as I have the Stratmosphere shifter which only has one setting (approx. 35% shift throw reduction).
Do some experimenting. I could think of two reasons for your weird "delay":
1. The shifter is not aligned properly. Play around with the main two allen screws.
2. The very short throw causes it. In this case, switch to another setting and see if it feels any better.
BTW, I'm experiencing such weird delay when shifting from 1st to 2nd, and although I played around with trying to align it differently, it didn't really help at all. I still have that annoying hesitation that prevents me from quickly shifting from 1st to 2nd. No way in hell am I going to win any 0-60 or 1/4 mile competitions with that thing :-(
I had this "delay" BEFORE the ss kit tho'..
the delay.. is like a pause.. not 1 FULL, and fluid motion going from 3rd to 4th gear.. it was there before the short shift kit.. I wonder what it could be..??
AudiWorld Expert
well...
I've been told that adjusting the shifter linkages in the transmission may help. However, the 1st to 2nd issue is much more common than the 3rd to 4th which you have.
If you're still under warranty, then have your dealer look at it, but you will have to put your stock shifter back in. Otherwise, the dealer won't touch it - they'll just blame it on the short shift kit.
If you're no longer under warranty, find an independent shop in your area that specializes in Audi and have them play with it. Personally, mine isn't so bad - I've been hesitant to take it to an indep. shop, and I also don't feel like putting my shifter back to stock so the dealer can figure this out. However, I don't remember my issue to be so pronounced when I was stock, which leads me to believe that my short shifter just amplifies the problem.
Some people also reported that their shifts have smoothed out after replacing the tranny fluid with synthetic lubricant. Redline MT-90 is da stuff! YMMV
Squidbert
11-02-2006 05:43 PM
mobe
15
02-28-2006 08:10 PM
Baiano
06-15-2000 10:00 AM
