Timing Belt Question
<center><img src="http://pictureposter.audiworld.com/8325/tbelt.jpg"></center><p>Once the belt is off does it matter if the sprocket I have circled in red moves? I know the other two can't move.
However, make sure there's no slack between that gear and the cam gear or between that gear and the crank gear. Leave all the slack between the crank and the cam on "the left" so the tensioner will deal with it.
Cheers,
Cheers,
I took it right off. No need to worry about alignment.
<img src="http://images4.fotki.com/v45/photos/1/131573/486729/wpump1-vi.jpg">
assembly and should remain in phase. The entire rotating assembly is balanced together.
belt of the cog and shafy itself back on/in. It really is not a great idea to "just spin it if you want"
