Timing belt tools? We don't need no steenking timing belt tools!
<ul><li><a href="https://forums.audiworld.com/a6/msgs/576401.phtml">x-post from the land of the larger cars.</a></li></ul>
Yes and no.
The crank tool makes it easier. I don't know about the guys in your shop, but everyone I know doesn't bother removing all the 8 mm bolts, we just remove the center bolt and pull the cam sprocket and the pulley as a unit. Saves time, and you need to pull the big bolt to change the crank seal anyway.
Ah, ok
I don't pull that unless the seal is leaking, and that is one reason to actually use the crank lock tool. Also it should be known that if that crank bolt is removed it needs to be replaced as it is a torque-to-yield bolt. I had to do one once and they had to special order the bolt....none of the local dealers carried it!
