torque specs for oil pan on 98.5 1.8t
If your talking about the AEB/ATW specs, here you go:
Bolt:
-10Nm(7ft lb)
-Use #3249(tool) hex ball socket to remove and install two rear bolts on transmission.
-tighten diagonally in sequence
Comments on Oil pan:
-clean contact surface before installing
-When installing oil pan on removed engine, note that oil pan is aligned with metal plate on flywheel side(ie oil pan projects out over engine block 0.8mm 0.031 in.)
-Before installing oil pan, spread thin coat of sealant AMV 174 004 01 on sealing surface between oil seal carrier and engine block
Hope this helps.
Bolt:
-10Nm(7ft lb)
Hope this helps.
Ground_Pounder_65
01-12-2006 04:15 PM
gamma500
06-22-2005 04:08 AM
|skolnick
11-03-2004 03:45 AM
