Toyo proxes 4 (205/55/16's)
Old 11-09-2008, 08:25 PM
1999Audi's Avatar
Default Toyo proxes 4 (205/55/16's)
Right now I have Toyo proxes TPT 205/55/16's, which is wear out, I want to buy new Toyo proxes 4.
Toyo web site state: Toyo proxes 4 "It is designed primarily for plus-fitment applications on sport compact cars, sports sedans, and coupes"
Need clarification, can I still use Proxes 4 with a stock rims or I have to do some modification?
Any suggestions?
Thanks
Old 11-09-2008, 08:38 PM
dowsett6's Avatar
they are what i run and they are working fine for me.
Old 11-09-2008, 09:05 PM
andysprague's Avatar
2nd. (but in 18's)
Old 11-10-2008, 02:24 AM
Member
Casablanca Avant's Avatar
why not go with a 225/50/16 for a bigger contact patch?
Old 11-10-2008, 04:54 AM
RKA
AudiWorld Uber User
RKA's Avatar
Yes, you can run them.
Old 11-10-2008, 06:17 AM
Pelican Pete's Avatar
Default I read something a few months ago which questions this logic
I don't remember if I read it here on AW, or in one of my car magazines. But basically, the contact patch of a tire is oval-shaped. And the size of that contact patch is determined by the load on the tire, and the inflation.
A wider tire will make the oval wider, but shorter. Given proper inflation, the overall contact area will remain the same for the two different widths of tire.
The advantage of running a wider tire is that the wider contact patch aids cornering.
That said, I have always believed in running the widest tire that will fit (except winter tires, which should be narrower). And in doing so I have always noticed an improvement in handling and road feel. However the improvement could more likely have been a result of the improved tire compound and tread pattern, rather than the size.
So in 1999's case, the Toyo Proxes4 is a terrific improvement over the TPT, regardless of size. If he has to contend with snow, then the 205 would be more appropriate for his climate conditions. But if no snow, then the 225 width would be a nice upgrade. And offer more rim protection.
-- P.
Old 11-10-2008, 06:42 AM
qfrog Ti20's Avatar
Default Also...
I think a wider tire is better for managing tire temperature due to the increased surface area for a given contact patch size.
Old 11-10-2008, 08:06 AM
Audi Junkie's Avatar
My guess would be more contact = more fricion = more heat.
Old 11-10-2008, 10:50 AM
1999Audi's Avatar
Default so I can safely buy 225/50/16 proxes4 and...
they are low profile -> would they look good even on stock height suspension and 16" rims size?
Thanks guys!
Old 11-10-2008, 11:01 AM
RKA
AudiWorld Uber User
RKA's Avatar
Default Yes you can safely run them.
Your second question is subjective.
Quick Reply: Toyo proxes 4 (205/55/16's)
