Tranny Fluid: What is the opinion of OEM vs. Mobil 1? (no luck STFA)
#11
.... that was 20K ago (89K on the car now), no problems and I certainly hope there won't be. He said he didn't want to a flush, but he does a lot of drain/fills and he hasn't seen any issues.
#12
m1 will coorode your brass syncros in your trans, so you need a gl4 fluid....like redline.
i used to have royal purple in both, and it sucked ***** in cold weather, so it got the boot after 30k. now the trans and diff are much happier (smoother) in the cold weather.
#20
Former Vendor
"Mobil 1 Synthetic Gear Lubricant LS 75W-90 combines wax-free synthesized hydrocarbon base oils and a specially designed extreme-pressure, limited-slip, sulfur-phosphorous additive system to provide a significantly higher level of performance in rear axles and differentials versus conventional fluids."
