Trans fluid and filter change for 98 tip v6
The fluid is about 20 bucks a quart and I think it takes about 7-8.
Use only oem fluid or zf approved fluids.
Don't flush just filter and gasket and fluid change.
These fluid/filter changes run me about $60 for Valvoline Maxlife ATF and a filter/gasket set. You'll need a couple of large hex drivers, some Torx bits, and equipment to get the fluid up into the transmission. I posted sometime back a few pictures of the very cheap setup that I use, which is basically a 7' hose, a funnel, and a ladder. You should also have VAG-COM diagnostics available to be sure the ATF temperature is OK when the filling is done.
OzzyLime
11-07-2011 10:02 PM
30V-6
08-31-2008 03:39 PM
Bobby Kinstle
02-17-2007 10:47 PM
