Trans grinding from 1st to 2nd
Anyone have any idea why my trans is grinding when i shift from 1st to 2nd? it only happens under really hard acceleration and doesn't happen all the time. any ideas besides me having to rebuild my trans?
or you're just not depressing the clutch all the way on the shift or engaging the clutch in between shifts.
since the ratio's are the furthest apart. i grind sometimes, but not often. if it only happens ocasionaly you should be ok. try changing the gear oil befor you do the supercharger. and get a spectrographic analisis done on it to check for major damage.<ul><li><a href="http://www.car-videos.com/tools/speedrpm.asp?Car=Select&Num1=205&Num2=55&a mp;Num3=16&AxleRatio=3.889&Ratio1=3.5& Ratio2=1.944&Ratio3=1.3&Ratio4=.943&Ra tio5=.789&Ratio6=&Ratio7=&Redline=7000 &
second grinds occasionally for me as well. double clutching is the trick to not grinding to almost any gear for me.
BergeyRPI
08-02-2012 10:39 AM
SilverAudIan
07-07-2006 10:55 PM
(R)S4 SmokedU /-///
11-24-2004 04:58 AM
Patrick B.
12-21-1999 01:06 PM
