Transmission leak (auto)
So when I bought my car he said there was a slow oil leak. Turns out it looks like a tranny leak behind the cv. Where can I find a seal for this?
Also, what color is the ATF in an Audi? the fluid dripping out is clear
Thanks
Thanks
HUGE relief, Audi fluid is a yellowish green
See here
http://www.audipages.com/Tech_Articl...servicing.html
See here
Which of the CVs is it? You may have gear oil leakage. Audi ATF is yellowish when new, but if its been in the tranny for a while, it will become darker.
You should probably check the level of the auto trans and front diff, but your leak may be motor oil. That's a common spot for a bad bank one cam adjuster seal or cam plug oil leak to show oil.
A42.0rgy
09-07-2004 10:49 PM
Moneytree26
06-12-2003 10:42 AM
