Transmission problems, Hard shifting,DTC code HELP from wet TCM
Hello, I have been looking for answers to transmission problem with my 2000 A4 Quattro. I hurt my leg and did not drive for a couple of weeks .Anyway first time I took car out it went into limp mode(3rd + rev)All gears lit. Dealer came and got it and said the TCM was wet from a leak somewhere. Anyway would not cover under warranty (I am still certified).Stealership wanted $1603CAD for the TCM!!! So thats why I want to be sure it is the TCM before buying one.
Anyway dried the car out and cleared the codes with my Vagcom and everything is fine now, no limp mode and no codes. But the car is shifting really hard. I was reading post about changing the ATF fluid,Filter, could this be the problem??From sitting maybe? Or even though the tcm is not giving any codes could it be fried?? I tried a throttle adaptation with no luck, recoded the tranny to 00022 , sport mode but no change. It is funny because shortly after I did the throttle adaptation and recode the car was drivng really well and I thought it was ok but next day the car was terrible agian, so I recoded to original 00002 and did throttle adap. Again with no luck. I will show you the original codes that I cleared and have not returned. I would really appreciate your help if you dont mind.
Thanks alot
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 3B0 907 551 G
Component: 2.8L V6/5V G01 0003
Coding: 07251
Shop #: WSC 08215
5 Faults Found:
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-10 - - - Intermittent
18034 - Powertrain Data Bus: Missing Message from TCU
P1626 - 35-10 - - - Intermittent
18056 - Powertrain Data Bus: Failure
P1648 - 35-10 - - - Intermittent
16815 - Warm Up Catalyst: Bank 2: Efficiency Below Threshold
P0431 - 35-10 - - - Intermittent
16805 - Warm Up Catalyst: Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
Readiness: 0000 1000
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 AT
Component: AG5 01V 2.8l5V USA 3132
Coding: 00002
Shop #: WSC 00000
5 Faults Found:
18223 - Pressure Control Valve 1 (N215): Short to Plus
P1815 - 35-10 - - - Intermittent
18155 - Transmission Solenoid Power Relay: Open or Short to Ground
P1747 - 35-10 - - - Intermittent
18233 - Pressure Control Valve 3 (N217): Short to Plus
P1825 - 35-10 - - - Intermittent
18228 - Pressure Control Valve 2 (N216): Short to Plus
P1820 - 35-10 - - - Intermittent
18238 - Pressure Control Valve 4 (N218): Short to Plus
P1830 - 35-10 - - - Intermittent
Thanks alot
Coding: 07251
Shop #: WSC 08215
5 Faults Found:
Coding: 00002
Shop #: WSC 00000
5 Faults Found:
