TRANSMISSION PROBLEMS NEED HELP!!!!
I have a 2000 Audi A4 quattro 1.8T. I recently had to have my automatic transmission changed, the car ran good at first then the next my the gears wont engage at all. The vag-com reading says incorrect gear ratio. Anyone have any idea what could be wrong now? or is this transmission toast to.
What codes did the vagcom scan show? Was the transmission rebuilt or swapped for used unit? Did you notice the gears slipping or harsh engagement when shifting before? The problem could be as simple as bad ATF fluid, poor connection from a sensor, or a dirty solenoid in the valve body of the transmission.
Jorge Vargas
09-08-2015 07:45 AM
S4intheOC
09-08-2015 12:12 AM
