Troubleshoot dead Cruise Control
My Cruise Control doesn't work and wondering if anyone can tell me how to troubleshoot the Audi Cruise Control. From what I can tell, the Audi Cruise Control runs off either pressure or vacuume, unlike Japanese Cruise. This is a bit out of my knowledgebase. THANK YOU...
Apparently it is dirty contacts inside the stalk. I have read that some parts cleaner from Radio Shack, sprayed strategically, can help restore operation.
Are you seeing this behavior, or is yours engaging and not holding speed?
i'm going to clean the contact 1st and see what happen. right now the cruise won't engage when i push the button.
Immediately after following the instructions, my CC worked again for a few days but now no longer works. I will have to try this again since the obvious problem is in the switch.<ul><li><a href="https://forums.audiworld.com/a4/msgs/2383753.phtml">>>> CLICK FOR LINKED POST FROM FAQ IN CASE YOU MISSED IT<<<</a></li></ul>
Try cleaning the switch didn't correct the problem. Now I got my A4 as used and CC never worked. I also notices I don't need to clutch in to start the motor but can't tell if this is normal or just German car thing. Any other ideas??
The lack of clutch to start the car seems to be "normal" on the older cars--it's like that on my '97 as well. Good luck
Andy
Andy
C5867
09-04-2003 03:25 PM
A4Turbo22
01-07-2003 01:35 PM
DavidG
09-24-1999 12:19 PM
