trying to remove the flywheel
#11
You know that a flywheel needs to be resurfaced when it develops that pattern. Kind of like a leopard print. From the look of your pics, it's just starting to get there. I can't tell from the pics, but does it look a little blueish? If it has a blue tint to it, then it needs to be resurfaced. That blue develops from the high heat against metal to metal contact. Hope that helps.
#12
I agree with you, a blue surface or dimensional variations (ie a groove) is reason to resurface, as would be any surface cracking. But I think we're looking at a buildup of deposits which hide the real story.
I've had flywheels that looked like this one clean up just fine. Still, if it doesn't, the next step is still available!
#16
Scotch first and if it doesn't work resurface. I too have been in the same spot and have almost always had to resurface it. Out of the 5, only 1 has been able to Scotch out of it.
#18
<center><img src="http://pictureposter.audiworld.com/26302/sanded4.jpg"></center><p>Should I get it resurfaced?
