Turbo that glows Red Hot!
How normal is it to have the turbo in a 1997 A4 Quattro 1.8t glow red hot after a 10 minute ride on suburban roads at about 40mph in 40 degree weather? The car is bone stock.
your wastegate might be stuck
Can you take the turbo off at all? Happened to me before. If that keeps up, your seals are going to go, and your turbo will die soon after. If you can, unbolt the turbo and run some hi pressure air into the wastegate. You should watch it actuate. If it's not opening and closing correctly, you've found your culprit.
-Me
-Me
Audi TT K04-023 red turbo
goa1217
09-15-2018 04:22 AM
MXSX19
12-01-2002 03:19 AM
