Turbo problems
I have a 97 a4 1.8tq auto, Lately my car has been idleing rough and i been hearing this loud rush of air noise everytime the turbo spools. I took out the hose which connects the turbo to the intercooler pipe and it was busted, i just replaced it and i still have the same problems,, any suggestions??
Search the archives for a post by UrS4 about pressure testing. You can build your own tester with PVC caps and brass fittings or I believe he can sell them to you already made.
Otherwise, you'll probably have to go through all the boost connections checking them individually.
Do you have a boost gauge or VAG-COM?
...as well as N75 duty cycle both of which can tell you the magnitude of the boost leak (if it is a boost leak).
jhanna
10-20-2006 06:39 AM
