Update on groan noise.. it's coming from the PCV system!
Original thread (with recorded noise): <a href="https://forums.audiworld.com/a4/msgs/2604900.phtml">https://forums.audiworld.com/a4/msgs/2604900.phtml</a>
Today when I got home from work, I could hear the groan groaning away. I decided to try and narrow it down a little.
I pulled off the inlet into the airbox, and noticed immediately the groan was loud coming from the intake (could hear through airbox).
First I clamped the vac line that goes to the BPV... noise didn't stop. Then I clamped some of the other air and vac lines, no change. I disconnected the secondary air from the airbox, no change. Then I unplugged the PCV hose that goes to the "puck valve" on the inlet hose. Suddenly the airbox went quiet. With the stethascope, I definetly could hear the groan coming from the pipe that goes to the puck valve from the PCV system. I played aroud with plugging up and then unplugging that pipe, and the noise went away.
Huh.. I guess I should pressure test (very small amount of pressure) the PCV system.
Maybe my puck valve is bad and the PCV system is getting pressure and or vacuum it wasn't designed to withstand?
Nermb
06-16-2017 07:44 AM
MainelyA8
9
08-12-2016 04:56 PM
joshb159
05-09-2005 06:23 PM
2003 2.7T SILVER
07-15-2004 01:20 PM
notjcs
08-09-2002 06:23 PM
