Urrggh!! Got home tonite and checked and i see my rear CA's a creaking. Maybe due to the neu/bils.
I noticed over the last month that i had started to feel the bumps a bit more on the rear of the car..and the rear self was moving about a bit more..on the ride home tonight...i got out and pushed the rear of the car and loe and behold it's creaking..hey at least there's only 2 on each side! i've already replaced the compleate set at the front! I reckon this must have been accelerated by the neu/bils which i've had in for about 10K miles (i have done 80K miles).
damn..will i have to get an alignment done when get them replaced?
sorry for the rant!!
which will trash your rear camber setting.
Disclaimer : Ohhh mighty Ed M. is it ok if I comment on these matters of geometry since I don't Auto-X, Drag Race or Track my car? I'd suggest you not take any of my advice, as I'm not a reliable source of information because the mighty Oz has deemed that he and those of his fray are the only ones qualified to speak on such subjects. If you should take the information I've provided to heart please do so knowing I'm neither fit nor qualified to give it and therefore you accept responsibility for any and all damages incured either directly or indirectly as a byproduct of the application of the information provided above.
Regards,
Regards,
I've never pulled it off myself...but it seems that to replace it with a new one you'd have to remove the eccentric washer bolt combo which holds the rear hub carrier / upright assembly to the rear lower control arm.
Besdies didn't you read my disclaimer Kris? ;-)
Got a thing for your US of A rear urs6 bridge spoilers!!where do i get one from,how is it attached??
AUDIS6DOIT
Audi Original "S" Cars
10-20-2008 08:03 AM
ModifiedA4
04-24-2001 11:12 AM
