Used a Pela 6000 oil extractor last night...worked like a champ
#13
its kinda tricky to get the filter turned with the oil inside of it and the bag all twisted but it works like a charm and is quick as well.
#15
Then you have older, dirty oil running thru a new, clean filter, only every other 5K maintenance routine. I thought that was one of the benefits of the synthetic oil.
#18
and not everyone has access to a lift or even ramps. Few people realize the filter can be grabbed from above too. In the bigger scheme of things, old filter is just fine, 1/2 q of oil is is fine...a lot remains behind in the engine no matter how much you drain it anyway. FTR- Honda says 5k on oil 10k on filter. In Europe, just oil service is more common on all cars. It's better than not doing it at all. Filters RARELY clog. Cut open the oldest filter you can find, no junk will be trapped in the pleats.
#19
The procedure with any oil extractor is to run the engine for @5 minutes before extracting. This is said to allow any particles to get suspended in the oil that you will then extract. One poster in the past said that he did the oil extractor, then opened the drain plug - nothing came out. This leads me to beleive that the oil extractor method is effective.
At what point do you say it doesn't work? What if you pull the drain plug, let it drain, then stick your finger in there and see some leftover oil/particles? How do you propose getting that out? and does it really matter?
If you are getting all (or nearly all) of the oil out on a regular basis - you're doing OK.
SoSlow
14
12-31-2007 08:07 AM
sparkhill
RS4 (B7 Platform) Discussion
21
08-26-2006 05:07 PM
BLAZNA420
04-28-2005 07:26 PM
