Vag error code 16506 throttle body position sensor signal too low
What exactly does this mean. It's pretty self explanatory, but what do I need to fix to get it to go away?
from bentley:
Harness connector on Throttle Position (TP) sensor -G69- loose or corroded due to moisture in the harness connector
Check harness connector for tight fit and contact corrosion, if necessary reconnect and/or clean
if no luck...
Wiring connection to Throttle Position (TP) sensor -G69- faulty, or sensor -G69- faulty
Check throttle position sensor -G69-
After that it indicates your ECU is faulty. Start with the first two ;-) HTH, let me know if I can do anything else.
if no luck...
ricekikr
10-29-2010 05:23 AM
kim84
Performance and Tuning
09-10-2006 02:47 PM
djdc
Audi 100 / A6 (C4 Platform)
12-24-2004 12:16 AM
shazam123
02-20-2002 05:48 AM
