VAG'd the car...need help!
Well here is the story fellas...I picked up a 99.5 A4 Automatic FWD (yes a sucky combination), but the deal was right.
I test drove the car, and it ran fine, idled perfectly, turbo spooled great, transmission shifted even better.
To make a long story short, the lady had trouble getting the title, so the car sat for 2+ months at her old apartment complex.
When I went to pick up the car 10 weeks later, I jumped it, it idle fine, but when I put the car in drive, the A4 would lag. I would give it gas and it will seem to not go. It almost seemed like the transmission was not engaging properly.
Well, shortly down the road, I heard almost like a turbo diesel noise, so I stopped, popped the hood open, and to my surprise the turbo was glowing red hot.
The car would start up, but it sounded like a turbo diesel or if exhaust valves where clanging.
Could the shifting problem be caused by a clogged cat, as well as the turbo glowing red, and the exhaust valves clanging (from back pressure)?
Here are the codes:
Need some serious help please! Anything will help! I am stumped!
VCDS Version: Release 805.4
Data version: 20090602
Sunday,12,July,2009,20:22:20:44466
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 128380km/79771miles
Address 01: Engine Labels: 058-907-55x-AEBN.lbl
Part No: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR AT D04
Coding: 06051
Shop #: WSC 06335
3 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-00 - -
17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded
P1326 - 35-10 - - - Intermittent
Readiness: 0010 0101
Address 02: Auto Trans Labels: 8D0-927-156.lbl
Part No: 8D0 927 156 BM
Component: AG5 01V 1.8l5VT USA 8508
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 N
Component: A4 KLIMAAUTOMAT D58
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
01206 - Signal for Duration of Ignition Off Time
27-10 - Implausible Signal - Intermittent
01044 - Control Module Incorrectly Coded
35-00 - -
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 K
Component: Airbag Front+Seite 0002
Coding: 00104
Shop #: WSC 06335
No fault code found.
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 911
Component: B5-KOMBIINSTR. VDO D15
Coding: 03242
Shop #: WSC 00000
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06335
4 Faults Found:
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 56: Radio Labels: None
Part No: 8N0 035 186 A
Component: Radio D03
Coding: 00117
Shop #: WSC 06335
End ---------------------------------------------------------------------
Here are the codes:
Coding: 06051
Shop #: WSC 06335
3 Faults Found:
P1545 - 35-00 - -
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
35-00 - -
Coding: 00104
Shop #: WSC 06335
Coding: 03242
Shop #: WSC 00000
1 Fault Found:
Coding: 16140
Shop #: WSC 06335
4 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00101
Shop #: WSC 06335
Coding: 00117
Shop #: WSC 06335
Just cleared all the codes, the car would not idle, but the engine sounds smooth (no valves clanging), I gave it just a little gas to keep the car running for about a minute. The turbo & cat or super hot to the touch.
It still threw this code:
Sunday,12,July,2009,20:38:15:44466
Coding: 06051
Shop #: WSC 06335
1 Fault Found:
P1545 - 35-00 - -
Readiness: 0110 0101
Coding: 16140
Shop #: WSC 06335
Coding: 00101
Shop #: WSC 06335
Coding: 06051
Shop #: WSC 06335
1 Fault Found:
P1545 - 35-00 - -
Coding: 16140
Shop #: WSC 06335
Coding: 00101
Shop #: WSC 06335
Sounds like you might need to do a "throttle body adaptation " thru vagcom.
Bothe the engine and transmissions loose their setup when the battery is dead. I can take a few miles to smooth out.
Did a TBA and the car seemed to idle fine for the most part. The RPMs would jump up and down very slightly.
You can physically see the turbo and exhaust get hot and I checked the tail pipe to see if there was anything flowing through the back. When at idle, it seemed fine. When giving it a bit of gas, there was an almost complete stop of flow through the end.
Clogged cat? Any suggestions would be appreciated!!
Look underneathe the car, if the cat is glowing red then it is clogged.
Also, if you can unbolt the muffler and see if maybe it is clogged up.
It sat for over two months, maybe something got stuck in there.
ralleyquattro
9
02-24-2005 11:45 AM
sou17
12
02-04-2004 08:33 PM
MXSX19
12-01-2002 03:19 AM
