vibration
it's pretty easy if you
jack the engine up and slide it on. I've done two mounts, and the second was easier to do after someone on here mentioned to jackup the engine and slide it on.
The only reason I asked was due to my engine doing something similar. Ended up being my snub mount was aligned correctly. Caused the engine to vibrate in the same RPM range. Next thing to do is a visual check on the engine mounts. Check to see if either one of them is leaking. If it is, then it's your culprit.
1999Audi
09-06-2011 05:19 PM
jimmyTT01
11-21-2006 09:51 AM
tdotquattro
09-29-2005 08:39 PM
