vibration at high speeds after adding Stern Power Ring...
I know my rims aren't perfect, and I know my left front tie rod end is bad... which is most likely to be causing the vibration felt now that the drivetrain is "hard-mounted" to the car's chassis via the Stern Power Ring?
Thanks
Thanks
someone sit in the back seat area with the lower seat out and feel the chassis where the vibrations are coming from... if dead center of the car close to where the center seat belts are then its just the differential mount.
.. the chassis of the car. My question was more: which underlying reason (bad tie rod end or dinged inner edge of rims) is the more likely one to cause this drivetrain vibration?
other than the wheels. do you feel vibration thru steering wheel or seat? that will tell you what end of the car is making the vib.
Troy H
Audi allroad
01-22-2004 05:26 AM
