A warning to those giving advice about what things to get for our cars...
If you are not 100% sure about the validity of your solution, it can be harmful to the person you're giving it too...
CASE IN POINT: I asked about which fluid to use for power steering? I got the answer, Pentosin CHF-11 from someone. This is incorrect. Pentosin CHF-11, as I've been informed by an Audi VAG Engineer, is a hydraulic fluid for specially designed pumps, specifically Porsches. Using this fluid will shorten the life of internal components in Audis (due to a difference viscosity and operating temperature). The proper fluid is G00080.
when I say I have a 96, it doesn't mean it applies necessarily to my car. Suggesting that I use Pentosin is a wrong assumption because it WILL cause damage to my steering assembly. My arguement is that next time soneone is quick to make a suggestion just for the sake of seeing their name on the board, they should really think about whether it really solves the problem. On the other hand, I also am suggesting everyone DOUBLEcheck all suggestions with a certified/qualified mechanic when it comes to vital vehicle components (not like fogs or something).
...and "I" know it was "correct" information.
I have not a care in the world for some dumbass "Audi/VAG Engineer" who says its not to be used. This is comming from the same *******s who will pull heads open for a valve check before checking coilpacks on a misfire.. I know its the right stuff, not saying you cant use G80, but CHF-11S is far superior than G80. Check the archives before you go accusing me of giving false information.
