washer fluid leak.... Just started
Old 01-10-2004, 07:49 PM
Junior Member
gr7hug's Avatar
Default washer fluid leak.... Just started
My washer fluid is leaking like crazy, i thought i was just out, but after going and trying to fill it up, it comes directly out. Any ideas where the problem could be? It comes out around/ in the drivers side front wheel, where the tank is.
Old 01-10-2004, 07:53 PM
Member
mnemonic's Avatar
Default there are clips that connect to the Headlight washers, thats where I would look.
have to take the front bumper off to check (90% sure).
Old 01-10-2004, 07:55 PM
Member
Yippers®'s Avatar
Default Sounds like the headlight washer pump .... common issue. The tank could be split (that also happens
to some).
Old 01-10-2004, 08:06 PM
Junior Member
gr7hug's Avatar
Thanks guys, looks like i'll be removing the bumper for my first time tomorrow! w00T! =(
Old 01-10-2004, 08:08 PM
Member
Yippers®'s Avatar
Default Just pull the drivers side wheel well liner. No need to pull the bumper unless and until you deter-
mine it is not the tank or the pump.
Old 01-10-2004, 08:13 PM
Junior Member
gr7hug's Avatar
good call..... im a noob, what can i say. Thank you wise man.
Old 01-10-2004, 08:15 PM
Member
Yippers®'s Avatar
Welcome
Old 01-10-2004, 08:18 PM
Member
mnemonic's Avatar
Default Can you access all the clips to the headlight washers, just through the well?
Seriously asking...I had the same thing happen to me and I had to pull off the bumper, but it was the clip closest to the Jet.
Old 01-10-2004, 08:42 PM
Member
Yippers®'s Avatar
Default No if it is a jet the easiest method is to pull the bumper.
The pump and or the tank itself seems more common a failure point.
Old 01-10-2004, 08:45 PM
Junior Member
gr7hug's Avatar
what should i look for at that area?
Quick Reply: washer fluid leak.... Just started
