washer fluid leak.... Just started
Old 01-10-2004, 08:57 PM
  #11
Member
Yippers®'s Avatar
Default The leak
Pour water in the tank and see from where it issues forth.
Old 01-10-2004, 09:04 PM
  #12
Eurostile's Avatar
Default take off the drivers side fender well liner
Mine usually leaks from a hose there, only when it becomes frozen though
Old 01-11-2004, 04:16 AM
  #13
New Member
customclothiers's Avatar
Default Re: Sounds like the headlight washer pump .... common issue. The tank could be split (that also hap
It is most likely the headlight washer pump - The one on top - another all too common Audi engineering mistake that will cost you money -
Open the hood - find the washer bottle at the front right of the engine compartment - you can see the washer pump on top - mine leaks due to a crack in the pressure ring that holds the pump in the bottle - I just pushed it back down into the sheath and glued it back in place (a temporary lazy day fix as it will eventually open up again with pressure and heat) - If you have the same exact problem with the plastic pressure ring &amp; don't want to buy a $40 pump you might try a hose clamp wrapped on a piece of rubber hose to keep pressure on the pump so that it doesn't slide up when you put pressure on the system. It should be a recall - everyone has this problem !!!!!<ul><li><a href="http://www.customclothiers.cc">http://www.customclothiers.cc</a</li></ul>
4taz
04-20-2009 09:08 PM
Jason Sowers(rs6's)
13
09-12-2007 01:56 PM
S40RCE:Smurf
NY / NJ / CT Discussion
11
03-09-2006 07:23 PM
Kent L
04-14-2002 03:54 PM
Quick Reply: washer fluid leak.... Just started
