Washer fluid reservoir grommets
Hey I need help my washer fluid reservoir keeps leaking on the drivers side corner is it the windshield washer pump grommet that's bad. I put a seal of rtv gasket maker and it still leaks should
I also change the level sensor grommet and the headlight washer pump grommet too thanks
I had a similar issue. I had found the problem to be that the washer fluid was leaking through the pump motor itself .This was the windshield washer pump, not the headlight washer. The pump can be accessed though the left front wheel well, behind the plastic liner. Replacing the pump stopped the leak.
a62.7t4ceo
10-24-2007 04:54 PM
Black2001S4
05-25-2005 06:38 PM
