Wastegate question, How can I test if the wastegate is functioning properly?
Do I have to remove the turbo? I ask because my k04 is quite laggy below 3500rpm. Any advice on open wastegates or wastegates in general is appreciated.
take a hemostat and clamp the compressor line from the turbo.
this makes the waste gate completely closed.
this is also dangerous to drive around like this, but good enough for a diagnostic.
at part throttle the turbo should kick in like a raped ape. as long as you drive at 1/4 throttle -you will be fine.
I would not suggest WOT.
if your wastegate is closed, you'll get the raped ape at part throttle. this means your lag problem isnt the turbo.
other things to do <b>first</b>:
-clean the TB and do a TBA
-check for boost leaks, check PCV valve under the intake manifold
-vag block 032
-log 3rd gear WOT block 115
-check the N75
-cat clogged?
-vag block 032
-check the N75
-cat clogged?
neildiamond
09-14-2002 12:59 PM
