Water Pump BTDT: gasket sealer, yes or no?
I'm half way through a timing belt,water pump, thermostat, headlight washer pump replacement job.
Do I need to put gasket sealer on the water punp gasket. Do I need to scrape off the existing seal on the engine block? It's a black sealant that looks tight and like it might enhance the new seal, or at least not interfere with it.
If it matters this is on the 1.8T.
TIA!
TIA!
if you do use any sealer use just enough so that you get very little "overage". HTH
MySTG3S4
04-19-2008 09:28 AM
Ertman
02-25-2007 12:12 AM
Zamore
02-19-2005 01:17 PM
computrtutr
01-30-2003 01:01 PM
