Water in rear passenger side footwell-which drain exactly?
Hi Guys,
I noticed that my rear passenger footwell was a bit damp today, so i'm assuming that one of the drains is clogged. I looked at the a,b,c pillars and none of them seemed wet to me.
I did some searching and I found the sunroof drain is a common problem. Would a clogged sunroof drain lead to water in this specific location? There is no water on my front passenger footwell so i ruled out water leaking from the cowl into the in cabin airfilter. I also changed my battery a month ago and made sure that the drain there was clear.
So is the sunroof drain the culprit? If so, where is it acutally coming in from.
Thanks in advance,
Peter
Thanks in advance,
Peter
RGa6
11
08-31-2005 06:42 PM
