Weird clunking and revving
#11
Second, according to the description, that cable is compatible with 409.1. The archive site that offers 409.1 for USB interfaces says that that version is "NOT for any 3rd party interfaces!"
(here: http://www.ross-tech.com/vag-com/download/archives.html )
#12
Second, the description of the cable you linked claims that it is compatible with 409.1. The site of the company that offers the software (we'll call them "RT") says that the USB version of 409.1 is "NOT for any 3rd party interfaces!"
#14
Here is the cable again
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!![Cool](https://www.audiworld.com/forums/images/smilies/cool.gif)
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
![](https://www.audiworld.com/forums/signaturepics/sigpic191288_1.gif)
#15
Thanks. Ordered the cable today. I also ordered a b manual last week and It should arrive today or tomorrow. I believe at least some of the codes will be in there, so I should be able to download the demo and get started as soon as the cable gets here. I'll post updates!
Btw, I tried using my buddy's rig the other day. He was able to pull a fault code from the ECU and get input from a few of the sensors, but couldn't do much else. It came back with code P1565, which is "Idle speed control throttle position lower limit not attained." He suggested cleaning the throttle body, which I plan to do as soon as I get the manual. Could erratic throttling be confusing the tranny and causing this problem?
#16
Cool. Cable is on the way. I also sent for the b manual last week and it should arrive soon. I'll post updates!
Btw, I tried using my buddy's rig a couple of days ago. He was able to pull ECU codes and get input from a couple of the sensors, but that's about it. It came back with a P1565, which is "Idle speed control throttle position lower limit not attained." He suggested cleaning the throttle body, which I plan to do as soon as I have the manual. Could erratic throttling be confusing the tranny and causing this problem?
#17
You may want to try a throttle body alignment to deal with P1565. Have you checked on the TCU yet?
#18
Okay, after a bit of tinkering I was able to scan. Turns out it won't recognize the interface unless it is plugged into the car...at least the first time.
Anyway, I got 4 codes:
1. P1602-Power Supply (B+) Terminal Low Voltage
-------This doesn't surprise me given the number of times the battery went dead when it was flooding. Battery is probably weak. It still starts up fine, though.
2. P1559-Idle speed control throttle position adaptation malfunction
and
3. P1565-Idle speed control throttle position lower limit not attained
-------Two codes on that bad boy...I'm guessing I need to clean the throttle body. If that doesn't work I suppose it'll have to be replaced. Don't I have to register to run an alignment manually?
4. (from the tranny) 00526-Brake light switch-F 27-00-Implausible signal. Read that this one can probably be cleared by simply stepping on the brakes once before scanning. Not worried about it as my brake lights are working.
Any advice ?
and
Any advice ?
#19
Ok, after some tinkering I was able to do a more complete scan.
Chassis Type: 8D - Audi A4 B5 Scan: 01,02,03,08,15,17,25,35,45,55,56 -------------------------------------------------------------------------------Address 01: Engine Controller: 4D0 907 551 AH Component: 2.8L V6/5V MOTR AT D01 Coding: 06251 Shop #: WSC 06325 3 Faults Found: 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent 17967 - Throttle Valve Control part (J338): Fault in basic settings P1559 - 35-10 - - - Intermittent 17973 - Throttle Actuator (J338): Lower Stop not Reached P1565 - 35-10 - - - Intermittent Readiness: 0000 0000
-------------------------------------------------------------------------------Address 02: Auto Trans Controller: 8D0 927 156 BQ Component: AG5 01V 2.8l5V USA 8511 Coding: 00000 Shop #: WSC 00000 1 Fault Found: 00526 - Brake Light Switch-F 27-00 - Implausible Signal
-------------------------------------------------------------------------------Address 03: ABS Brakes Controller: 8E0 614 111 M Component: ABS/EDS 5.3 QUATTRO D31 Coding: 0273004134 Shop #: BB 24302 No fault code found.
-------------------------------------------------------------------------------Address 08: Auto HVAC Controller: 8L0 820 043 D Component: A4 KLIMAVOLLAUTOMAT_D75 Coding: 04162 Shop #: WSC 06325 No Faults Found or DTCs not supported by controller or a communication error ocurred
-------------------------------------------------------------------------------Skipping Address 15-Airbags
-------------------------------------------------------------------------------Address 17: Instruments Controller: 8D0 919 930 LX Component: B5-KOMBIINSTR. VDO D10 Coding: 06262 Shop #: WSC 40829 No fault code found.
-------------------------------------------------------------------------------Address 35: Centr. Locks Controller: 8L0 862 257 N Component: CV-Pump D05 Coding: 16140 Shop #: WSC 06325 7 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - -01371 - Alarm triggered by Door Contact Switch: Driver's Side 35-00 - -01374 - Alarm triggered by Terminal 15 35-00 - -01370 - Alarm triggered by Interior Monitoring 35-00 - -01366 - Opened Due to Crash Signal 35-00 - -00955 - Key 1 09-00 - Adaptation Limit Surpassed 00956 - Key 2 09-00 - Adaptation Limit Surpassed
-------------------------------------------------------------------------------Address 45: Inter. Monitor Controller: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00102 Shop #: WSC 06325 3 Faults Found: 01381 - Alarm triggered by Anti-Theft Sensor: Rear Right 35-00 - -01382 - Alarm triggered by Anti-Theft Sensor: Front Left 35-00 - -01383 - Alarm triggered by Anti-Theft Sensor: Front Right 35-00 - -
-------------------------------------------------------------------------------Address 56: Radio Controller: 4B0 035 186 Component: Radio D01 Coding: 00201 Shop #: WSC 00000 No fault code found.
End --------------------------------------------------------------------------------------------------
I _think_ I successfully ran an adaptation on the throttle body and it said "ADP OK." Could be an old code still stored in memory...? I tried to clear all the codes before and after the scan, but it said "You require a professional level interface to do that" or something along those lines. How do I get rid of 'em?
Also, after that adaptation I took it for a test drive. Same problems as before :-(
#20
Go into each module and clear them individually. Then rescan and repost. We'll go from there.
