weird sound coming from borla exhaust with k04 turbo
i recently purchased the k04 kit from AWE. the borla exhaust was back ordered so at first i was just using the stock exhaust. everything was fine and i was loving it. then the borla exhaust came and that was installed. it has a nice tone but at about 3500 rpm or so under full throttle, there is a very loud, distinct sound coming from the exhaust. it sounds like wind howling or screeching through a pipe. so much so that it drowns out the regular sound of the tuned exhaust. i asked the shop where i had it put on and they said it was normal and it was the sound of the turbo echoing through the exhaust pipe. i have driven other turbo cars and they do not make this noise and it didn't make the noise with the stock exhaust. does any one else have this same setup? and if so, do you have this same problem? i don't really like this noise but would a different exhaust eliminate this sound?thanks
you might want to make sure they welded it correctly...
or if its a bolt on make sure all the pipes are flush mounted and there are no gaps showing. You might have an escape somewhere in the system.
ploglet
09-11-2007 10:56 AM
uphilli
08-02-2002 01:39 PM
shorty1.8tq
05-29-2002 06:38 PM
Randy M
08-15-2001 12:15 PM
StevenH
05-14-2001 03:33 PM
