well for all of those who say the tranny is bulletproof... fyi not true
#21
One big problem with that, he claims it died
while in stop/go traffic so it isn't like he was close to using all the power the car makes.
Might not even be his transmission that died and just something else in the driveline.
#22
Mike, you should have guessed that cost isnt the concern on my car, longevity and performance are!
They are expensive - without a doubt, s2 trannys sourced from Europe are only around 2k$, and are almost the same.
#23
I dont know where you got that, I thought it was very easy! Expensive yes, hard no!
But then again I dont know how hands on many of you are. It didnt present a problem, and I have changed one out x 2 in one day. Need a diff. subframe, need new s4 linkage and JHM pieces, need to do some trimming to the driveshaft, but that is about it. All of this is bolts and nuts.
#26
hard is a relative term. if you swapped engines, you could easily swap transmissions...
the most i've ever had to do when swapping transmissions is make new bracketry. You can bolt many transmissions in using different subframes, but sometime there is no combination that will work and it is easier to make some brackets (which is generally pretty easy).
#27
I didn't do the swap, I could have and would have had not problems doing so if I had time.....
but with my work weeks and 2nd degree I have to put my priorities else where. Next project car is going to be 100% DIY and will not start till I own a house with a garage
T-28-Quattro de VT
11-30-2002 07:19 AM
Dex4
06-19-2001 05:56 AM
