Well appearantly my small coolant leak is no longer a small coolant leak =-(
Just went out to my car, started it, fine. !!!!!!!!!!BEEEP!!!!!!!!! Freakin coolant alarm, checked it out, nothing, tank is completly empty. I know its been leaking for a little bit now, just don't have a garage to check it out. Minor leak, had to add a little coolant once every couple weeks. Now its just empty..
Same as this guy too, same spot, I think its the same issue. Damn it! Its raining and cold like a ****..<ul><li><a href="https://forums.audiworld.com/s4/msgs/998383.phtml">same issue on someones elses car</a></li></ul>
or, if after 6, call ahead and ask them to leave some for you. I've done that before and the sales manager filled it for me.
and leak from there too. Ju stbe glad that it's not coming from the pump.
FWIW, the G12 is cheaper at VW dealers, I get it for $15/gal... you may even find it cheaper.
if you do end up filling it with water, make sure to do a good flush before you put in your new 50/50 g12/water mix.
ucf_motorcycle
9
04-14-2010 10:41 AM
LosGatosS4
16
10-10-2003 12:56 PM
Kirath ¾-B0§t0n
9
10-30-2002 12:57 PM
