Went to the local dragstrip last night for some fun run, or run what you brung heads up action
First, I'll start with an overview. Admission is $7 dollars. Hot dogs are $50c. There is one port-a-john and lawnchairs behind a fence. The location is Smithfield, OH. 20 minutes into the countryside, at the fairgrounds. The track was surprisingly good. Excellent really. Simple tree at the start, and a win light(incandescent light bulb) at the end.
AWESOME. We had a blast running our imports against all those old school, back yard mechanic built hot rods. Some of which were pulling the wheels at the start.....and two would pop up when they slammed second gear. These old boys were making some power. There were a handful of alcohol/nitrous methane fueled beasts around....but most were your down home V8's with open headers.
The only other German made car there was a MkIV GTI, the rest were turbo civics, integras...etc. There was a fairly impressive 240SX.....anyone care to field a guess what engine swap he did?
Yup. Skyline powered. Very clean, sounded amazing. No traction at all. That guy was in desperate need of slicks.
My best time was a 9.28 with a reaction of .07x. Yes, 1/8th mile track. The GTI was running 9.5-10.0's. He was only chipped, zero other modifications. I have never felt the weight of the A4 like I did last night. What a HEAVY pig. My buddies 1st gen Talon FWD, which is moderately built running on Hoosier slicks, was down in the mid-to hi 8's. I know we have the same amount of power, just an enormous weight difference.
All in all, good times. Is it possible to guess what my 1/4mi. time would be from this info?
This is commonly referred to as a "christmas tree", in drag racing terms
<img src="http://cdn.overstock.com/images/products/3/L11056691.jpg">
a drag race:
A drag race pits two vehicles against each other over a straight, measured distance from a standing start. The standard distances are a quarter-mile (1,320 feet/402.3 m), 1000 feet (301.5m) (contested in the highest horsepower classes only), or an eighth-mile (660 feet/201 m). A standard drag racing event involves several classes, each competing in their own single-elimination tournament of head-to-head races.
Before each race (also known as a "pass"), each driver is allowed to perform a burnout (which heats the tires and lays rubber down at the beginning of the track, improving traction), then lines up (or "stages") at the starting line. Informal drag races can be started by any means, including flag-waving and arm-dropping. Professional drag races are started electronically, with a series of vertically-arranged lights known as a Christmas Tree. A Christmas Tree consists of a column of lights for each driver/lane. In each column, the top two lights are small amber lights connected to light beams on the track, which when broken by the vehicle's front tire(s) indicate that the driver has pre-staged (approximately 7 inches from the starting line) and then staged (at the starting line).[1]
Below the staging lights are three large amber lights, a green light, and a red light. When both drivers are staged, the tree is activated to start the race, which causes the three large amber lights to illuminate, followed by the green light. There are two standard light sequences: Either the three amber lights flash simultaneously, followed 0.4 seconds later by the green light (a "Pro" tree), or the amber lights light in sequence from top to bottom, 0.5 seconds apart, followed 0.5 seconds later by the green light (a "Sportsman" or full tree). If the driver leaves the starting line before the green light illuminates, the red light for that driver's lane illuminates instead, indicating disqualification should no further infractions occur.
Several measurements are taken for each race: reaction time, elapsed time, and speed. Reaction time is the time from the green light illuminating to the vehicle leaving the starting line. Elapsed time is the time from the vehicle leaving the starting line to crossing the finish line. Speed is measured through a speed trap near the finish line, indicating the approximate maximum speed of the vehicle during the run.
The winner is the first vehicle to cross the finish line (and therefore the driver with the lowest total reaction time + elapsed time). The elapsed time is a measure of performance only; it does not, per se, determine the winner. Because elapsed time does not include reaction time, a car with a faster elapsed time can actually lose the race if the driver does not react to the green light fast enough. In practice, it is advantageous for the driver to "jump the gun" by a fraction of a second, starting the car during the split-second interval between when the yellow light goes out and the green light goes on. However, if the car leaves the front light beam before the green light comes on, the driver has "red-lighted" (because the red light is lit on the Christmas Tree) and should no further fouls happen during the race, is disqualified. Once a driver commits a red-light foul, the other driver can also commit a foul start by leaving the line too early but would win because he or she would leave the line slower. A driver who gets a substantial lead at the start is said to have gotten a "holeshot". A win where a driver wins a race with a higher elapsed time but lower reaction time is known as a "holeshot win".
It is also possible for a driver to be disqualified for other infractions, depending on the rules of the race, including crossing the centerline between lanes, touching a wall, striking a track fixture, failing to stage, failing a tech inspection, or running faster than expected/allowed for the assigned class. In boundary line violations, if the offending driver have made a clean start, and the red-light driver does not commit the violation unless forced by the offending car for safety reasons, the driver who committed a red-light foul wins.
In the common Eliminator racing format, the losing vehicle and driver are removed from the contest, while the winner goes on to race other winners, until only one is left. In cases where a driver has no opponent for a round, the driver makes a solo pass or "bye run" (in order to at least partially eliminate the advantage that would otherwise come from the engine having one less run on it) to advance to the next round. In most Eliminator formats, the bye runs take place only in the first round. On bye runs, some drivers may choose to drive slowly so as not to stress the car unduly, though choice of lane in the each round is often determined by time in the previous round, making this strategy possibly detrimental. Unlike the NHRA, many European events feature a consolation race where the losers of the semifinal rounds race for third place, the final spot on the podium, and standings points.
During drag racing events, vehicles are classified by various criteria that take into account the extent of modifications to the car. These criteria include engine capacity, configuration of cylinders, frame type, vehicle construction materials, wheelbase, horsepower to weight ratio, number of cylinders, whether or not power adding devices such as turbochargers, superchargers or nitrous oxide are employed, vehicle type (such as car, truck, et cetera), or even make and model for limited entry fields. The aforementioned divisions are in place to ensure that the cars are evenly matched during the race. (not all of these can apply)
Drag racing vehicles are special in that they are modified to be lighter and more powerful than in their standard form. A lighter vehicle means that the power-to-weight ratio is increased and hence a greater acceleration will be achieved. Power increases vary depending on the extent of the modifications to the engine.
</wikipedia>
anymore questions?
a drag race:
</wikipedia>
anymore questions?
a 10 second or better car depending if it has highway gears or pillar to post gears. I dont know many people who run both, the 1/4 mile times show a 1/8th mile time, low top end w/quik time means car was geared for the 1/4, hi top end speed means it wasnt done for qtr. but may still really be fast (low time with a hi top speed being the more telling that it wasnt a 1/4 mile car). So it is hard to tell with much accuracy. If car has a low time or a hi top speed, they have some power.
4000fixes
09-21-2007 06:39 PM
Riz3
Audi Original "S" Cars
10-20-2006 05:12 PM
1SeriousPig
07-03-2005 11:28 PM
