Wet Braking: My first encounter in 5k miles...
Guest
Posts: n/a
Last night after racquetball, in medium down poor, after about 10 mins of highway driving. Whilst merging I needed the slow down, but after applying brakes and feeling the usually pressure on my foot, the car was not slowing. Very Wierd/Alarming/Terrifying. Had never noticed this problem before.
I'm assuming that cross drilled or slotted rotors will mostly if not completely illiminate this problem.
In looking at the rotors available at adirondak aka www.germanautoparts.com. I really like the look of the slotted rotors, but have a feeling the cross drilled will be better for fade resistance, and or taking the car to the track (one of my future goals, along with th PES super charger).
Can anyone who has these or other cross drilled or slotted rotors verify their wet brakng resistance. 'Cuz after last night I'm ready to buy today.
Kind Regards,
slack
99.5 2.8M<ul><li><a href="www.germanautoparts.com">www.germanautoparts .com</a</li></ul>
Kind Regards,
slack
Guest
Posts: n/a
But I haven't installed them yet. My reason for getting them is the same as yours. After going through a whole CO winter without the wet braking problem, I suddenly experienced it when I had to make a panic stop on the highway from 75mph (traffic was stopped in front of me)! Fortunately, there was a slot in the lane to my right, or I would have had a crunched A4. The funny thing was, that this happened while I was driving to CO Springs to my TAP stage 2 installed. It will be a few more weeks before I have them installed, but I'll post my impressions after I use them a bit and then again after some wet driving. Good luck!
CraigB
CraigB
Guest
Posts: n/a
F - Ate Powerdiscs
R - Stock rotors
Mintex Red Box all around
SS brake lines and Ate Super Blue.
I'll be getting it installed in the next couple weeks and will post impressions after some wet weather driving.
Dave
'97 1.8TQMS Wett<ul><li><a href="http://131.107.68.28/a4.org/registry/details.asp?car=161">My Car</a></li></ul>
R - Stock rotors
Dave
Guest
Posts: n/a
...I've got Rofren pads front and rear with ATE slotted rotors up front. We've finally gotten some heavy rain in the Mid-Atlantic area recently after a long dry spell. I was hoping that the slotted rotors would help eliminate that "Oh ****" feeling I occasionally get when I put my foot on the brake after not using the brakes for a while. Guess what, problem still exists. I'm starting to think that it's the Rofren's and I'm thinking about swapping out the fronts for a set of Mintex to see if they're any better.
<A HREF="Mailto:andy_hedin@hotmail.com">Andy Hedin</A>
'97 A4 1.8Tqms, Garrett 1.0 Bar, ABT Filter, APR/Borla Exhaust, Euro Headlights, more...
Guest
Posts: n/a
Stainless steel lines are not a replace-and-forget item. For safety's sake, you should replace them regularly (perhaps once a year).
The problem is that over time, the SS can fray, and then wear on the underlying nylon hose that it is protecting. Then, one day, all of a sudden, the brake line is cut by the SS, and you have no warning when the brakes are suddenly not working. SS protects the brake line but it also hides evidence of impending doom.
Professional racers use SS brake lines for their strength, but they also replace them on a regular basis.
Be safe.
Be safe.
Guest
Posts: n/a
I heard that Audi has a new inner brake shield, that should solve it. Do the Rofrens have a center groove in them? If not, cut a pair in about 2mm wide parallel at 1/3 from each end, or criss-cross. I make the cut about 1/2 the thickness of the pad material.
The problem is not the pad material per se, it is the incompressability of the water.
Guest
Posts: n/a
I follow what you're saying about the incompressability of water...but wouldn't my slotted rotors help in that respect by allowing the water to escape from under the pad quicker? BTW, the Rofren pads don't have any slots on them.
Andy Hedin
Andy Hedin
Guest
Posts: n/a
It's not that the disk slots/holes aren't working, they just are not enough surface area to make much difference. Slotting the pad is more effective as it gives more edge (bite) to scrape the water into the holes.
To give an example, the favorite pads of touring drivers are the hinged two element pad and the 6-12 pads. It is the contact of all the pad edges that give good feel and water dispersion.
