What is a "3357 triple square socket driver "?
It's about $20. Basically, it looks like a huge Torx bit with a hole in the middle.
I think Snap-On carries it as well.
If you're planning on changing the fluid, also take a look at the trans fill plug. Some cars, it's the same as drain, and others requires a 17mm allen, which is probably a special order tool as well(I made my own using a bolt and an old socket)
It would suck to drain the fluid and then find out you can't fill it back up!<ul><li><a href="http://www.zelenda.com/">http://www.zelenda.com/</a></li></ul>
and put a funnel on the end.
Trans takes 2.97 quarts of 75w90, I used Redline MTL. After adding about 2.5 quarts, watch for overfilling.
Mr Paul [T-28]
05-30-2007 02:49 PM
EastSidinA4
10
02-20-2007 09:53 AM
Åüdios69
07-10-2002 10:46 AM
