What am i doing wrong? HELP!
2001 1.8T AWM
The story is too long with this car so i will make it short, i have changed the timing belt water pump and all the other good stuff, while i than opened the valve cover and found that the tensioner guides were broken, so i ordered a new (aftermarket) tensioner and a new chain, i put it all together and now i am getting these codes, oh and i changed the camshaft position sensor so it cannot be that either.
What is wrong??? is my timing on the chain wrong? It was (almost) perfect, meaning the intake cam was maybe 2 mm off, but still on the marks,
timing belt? i made sure that it was as tight as can be on the crank-waterpump-camshaft side, and i don't think that it could go another tooth (too tight)
PLEASE HELP
16725 - Camshaft Position Sensor (G40)
P0341 - 35-00 - Implausible Signal
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 35-00 - Incor. Correlation
16395 - Bank 1: Camshaft A (Intake)
P0011 - 35-00 - Retard Setpoint not Reached (Over-Advanced)
PLEASE HELP
30V-6
9
02-25-2009 07:16 AM
SteveK-OO (MN)
30v V6 Discussion
16
06-14-2008 07:32 PM
