What bolts can't I reuse doing a DIY clutch replacement?
I am changing the clutch in my sister's 99.5 A4 1.8TQM next week and am getting the parts together. I have read the tech articles and have all the right tools (I have to check on the triple square torx).
My question is are their any bolts that are going to break or can't be re-used? I looked most them up in ETKA so I have some part numbers. If there is anyhting else I should do while I have it off please let me know. Oh and does the needle bearing need to be replaced when I take the FW of to have it resurfaced?
Thanks
Thanks
The Flywheel bolts can not be reused
You must replace those. I'd just get the Pressure Plate bolts as well, I always replace all flywheel/PP hardware when I have to remove any of them.
A comment...
<center><img src="http://samstagsales.com/images/vw_matra_3176.jpg"></center><p>Bolts that should be replaced:
-flywheel to crank
-pressure plate to flywheel
Yes, replace the pilot bearing anyway. It should be done when replacing the clutch. The pic is of the factory clutch centering tool and press tool for the pilot bearing, tool#3176. You might consider replacing the following while your in there:
-trans guide sleeve & seals
-trans output shaft seal
-rear main seal
The cost of the parts in minor.
-flywheel to crank
-rear main seal
UrScubed
Audi Original "S" Cars
11
11-16-2008 11:12 AM
computrtutr
01-28-2007 11:08 AM
Neo1130
01-04-2007 06:27 AM
Skyler@Achtuning.com
07-13-2005 11:45 AM
