What does 90 in lbs feel like?
I finally got a torque wrench and am tightening the lug nuts on my wheels. I think the spec is 90 in lbs. Well it feels a lot lighter than I used to tighten them or for that matter the way they were tightened from the factory.
Is the spec I have close? Is 90 in lbs something a 2 year old can handle? Or am I adjustting my torque wrench all wrong?
I hope you're using a large enough torque wrench...some of the more precise ones read in (in/lbs)
but those are good for putting in spark plugs and such...not wheel bolts. You should torque to 90 lb-ft if you don't have the proper torque wrench just put em on tight with the stock bar.
If you need a larger torque wrench Harbor Freight and Tool sells them at a great price... www.harborfreight.com
Regards,
James R.
2001 A4 1.8TQMSXP (Oettinger Pedals, Oettinger RE's 17x8 Yoko AVS Sports 225/45/R17, Euro Xenon Housings, Bailey BPV and RS4 Grille)
Regards,
James R.
If your torque wrench is larger/longer than your regular tire wrench,
it will take less effort to exert the same force and that can make it feel like you're not tightening the bolts as hard. I suspect most people over tighten without a torque wrench and never know it.
Slush Puppie
03-13-2005 09:47 AM
KWHM3
9
12-02-2004 08:48 AM
BLKPERL
12-04-2002 03:23 PM
2002_A4_1.8T_Quattro
07-25-2002 04:02 AM
Dank
Wheels & Tires Discussion
12-31-1998 08:38 AM
